SHAPE command
Places shapes in drawings.
Icon:
Note: Before you can place shapes in drawings, you must first load a SHX shape file with the Load command.
方式
Enter the name of the shape and specifies the insertion point, the scale and rotation angle to place it in the drawing.
Shapes are an early version of blocks that were highly efficient but difficult to code; shapes are rarely used anymore. The SHP format is also used by certain fonts; it contains a flag to distinguish between shapes and fonts.
Options within the command
- ?列示
Lists the names of shapes loaded in the current drawing. Reports the file name and names of shapes:
Shape file: C:\temp\611.shx
HAIE BOIS
HOTALU BATALU
CLOTUR FROST
RAILS PGA
PGAE PGBR
If no shapes are loaded, reports: “No shapes loaded.”
