SIMPLIFY command
Simplifies entities.
Icon:
Reduces the number of vertices of polylines, splines and non-associative hatches with geometry boundaries represented by polylines, without changing their general shape.
Note: Simplified entities are easier to manipulate and can
significantly reduce file size.
Options within the command
- Simplify
- Reduces the number of vertices.
- sMoothen
- Controls whether consecutive straight segments (at least three), of
which the endpoints lie on an arc, are replaced by a bulged polyline
segment.
- Maximum arc's length between each two adjacent vertices
- Specifies the maximum arc's length between each two adjacent vertices.
- Maximum arc's angle between each two adjacent vertices
- Specifies the maximum arc's angle between each two adjacent vertices.
- Minimum number of vertices per arc
- Specifies the minimum number of vertices per arc.
