SINGLETON command
Determines whether (or not) multiple copies of BricsCAD can run at the same time.
Note: This command can be entered transparently during commands (‘singleton).
Options within the command
Yes
Allows only one copy of BricsCAD to run.
No
Allows two or more copies of BricsCAD to run.
Note: Some third-party applications run only in a single instance of BricsCAD.
