SINGLETON command
Determines whether (or not) multiple copies of BricsCAD can run at the same time.
Note: This command can be entered transparently during commands
(‘singleton).
Options within the command
- Yes
- Allows only one copy of BricsCAD to run.
- No
- Allows two or more copies of BricsCAD to run.
Note: Some third-party applications run only in a single
instance of BricsCAD.
