SKETCH command
Creates lines or polylines from a freehand sketch.
Icon:
Alias: FREEHAND
描述(D)
Creates a series of individual lines or a polyline by sketching freehand.
Methods to begin a sketch
This command has 1 method to begin creating a sketch:
- 徒手描绘记录增量
- 徒手描绘记录增量
- Begin creating a sketch by specifying the length of the sketch line segments. A small segment length creates a smoother sketch but increases the size of the drawing. The length is saved in the SKETCHINC variable.
- 按 Enter 或点击切换
- Press the Enter key or click the left mouse button to lower the pen. The cursor changes to a pen, automatically sketching as you move it.
- 按 Enter 或点击切换
- Press the Enter key or click the left mouse button to raise the pen. You can move the cursor without drawing.
Options within the SKETCH command
After you begin creating a sketch, the following options may be available:
- 删除
- Erase sketch lines sequentially by dragging the cursor along the sketch from either endpoint. Click the left mouse button to stop erasing and start sketching.
- 连接(C)
- Continue to the last sketch point, after raising the pen, by passing the cursor over the end of the previous segment.
- 保存并结束
- Save the sketch and end the command. Each continuous sketch is saved as a series of individual lines or a polyline based on the SKPOLY variable.
- 不保存离开
- Exit the command without saving the sketch.
- 记录(保存)
- Save the current sketch without ending the command, allowing you to continue sketching.
