SMEXPORTOSM command
Exports a sheet metal solid to an Open Sheet Metal (.osm) file format.
Icon:
Displays the Save OSM file dialog box, which allows you to select a folder for the exported file.
Method
The .osm part is saved as mm- or inch-based, depending on the value of the document MEASUREMENT system variable. Document INSUNITS are considered for proper scaling.
Note: You can set the accuracy of the approximation and the
minimal length of the document.
Options within the command
- add Decorations
- Allows you to export adjacent non-sheet metal parts in same .osm part.
