SMEXTRUDE command
Creates sheet metal part by extruding a planar polyline.
Icon:
描述(D)
Creates sheet metal part from a planar polyline by extruding it orthogonally to the plane of the polyline.
方式
Select a planar polyline and specify the height of extrusion.
The thickening direction of the extruded surface is applied for each flange separately, to preserve the overall dimensions of polyline.
The overall dimensions of the Sheet Metal part match the dimensions of the extruded polyline.
