SMFLANGE command
Creates a base (initial) flange.
![BricsCAD Mechanical](https://static.bricsys.com/help/images/V23/en_US/command-reference-mechanical.png)
Icon:
Creates a base (initial) flange of a sheet metal part from a closed planar profile.
Note: A base flange is created for each selected closed
polyline or region. In the Mechanical Browser a body and a flange are
added for each entity.
Options within the command
- Up
- The flange is extruded on top of the base entity.
- Middle
- The flange is extruded on both sides of the base entity.
- Down
- The flange is extruded below the base entity.
- Accept model
- Accept the current extrusion.
