SMFLANGEBASE command
Creates a base (initial) flange.
Icon:
描述(D)
Creates a base (initial) flange of a sheet metal part from a closed planar profile.
Note: A base flange is created for each selected closed polyline or region. In the Mechanical Browser a body and a flange are added for each entity.
Options within the command
- 上
- The flange is extruded on top of the base entity.
- 中间
- The flange is extruded on both sides of the base entity.
- 下
- The flange is extruded below the base entity.
- 接受模型
- Accept the current extrusion.
