SMFLANGECONNECT command
Closes gaps between two arbitrarily oriented non-coplanar flanges.
BricsCAD Mechanical
Icon:
Method
Select planar thickness faces of two flanges to connect them.
Note: If SELECTIONPREVIEW system variable is 2 or 3, thickness faces of flanges are highlighted. Press the TAB key to select obscured faces.
