SMFLANGEROTATE command
Rotates a selected flange of a sheet metal part.
Icon:
描述(D)
Rotates a selected flange of a sheet metal part with automatic selection of the rotation axis depending on the design intent.
Note: A dynamic field angle displays the angle between the selected flange and the base flange. You can press the TAB key to display the absolute rotation angle.
