SMFLIP command
Swaps sides of a selected flange.
Icon:
Swaps sides of a selected flange so that reference faces are on the other geometric side of the flange. Optionally shifts the flange over the thickness of the sheet metal part.
方式
Select a 3D solid or a flange face or press Enter to flip sides for all flanges.
Options within the command
- 只翻转凸缘侧
- Turns OFF the shift of flanges by thickness, in this mode reference sides for selected flanges are just swapped.
- 整个模型
- Applies flip operation to all flanges in the drawing.
