SMQUICK command
Suggests the optimal set of splits/junctions/bends for a shelled solid.
Icon:
Method
This command can be used on 3D Solids and on Sheet Metal solids.
If a 3D Solid is selected, this command can be used to:
- Create shelled solids.
- Create reliefs.
- Convert hard edges into junctions and bends.
If a Sheet Metal Solid is selected, this command recognizes its features and creates reliefs, junctions, and bends.
Options within the command
- Enter shell offset distance
Specifies a distance.
Note: If a positive distance is entered, the body shells outwards. If a negative distance is entered, the body shells inwards.Note: If the shell offset distance is larger than 3D solid, the command fails.
- Skip
- Skips the creation of shelled solid and acts similar to SMCONVERT command.
- Select optimization mode
Select a mode to optimize the model.
- Off (1)
- Creates bends for all hard edges.
- Auto (2)
- Creates bends, junctions and split.
- Interactive (3)
- Gives suggestions for bend, junctions and split using a widget interface. Choose to apply the suggested configuration or change the suggestions.
