SPHERE command
Creates a 3D Solid in the shape of a sphere.
Icon:
Note: In BricsCAD Lite, which doesn’t support 3D Solids, the SPHERE command launches the AI_SPHERE command.
Creates a 3D Solid in the shape of a sphere. Choose from a combination of options including center, radius and diameter.
  1. Center
  2. Radius
  3. Diameter
Methods to create a sphere
This command has 1 method to begin creating a sphere:
  • Center of sphere
Center of sphere
Begin creating a sphere by specifying the center then:
Set radius of sphere
Specify the radius of the sphere.
Additional option: [Diameter]
Option within the SPHERE command
After you begin creating a sphere, the following option may be available:
Diameter
Specify the diameter of the sphere.
