SPHERE command
Creates a 3D Solid in the shape of a sphere.
Icon:
Note: In BricsCAD Lite, which doesn’t support 3D Solids, the
SPHERE command launches the AI_SPHERE command.
Creates a 3D Solid in the shape of a sphere. Choose from a combination of options
including center, radius and diameter.
Method
This command has 1 method to begin creating a sphere:
- Center of sphere
- Center of sphere
- Begin creating a sphere by specifying the center then:
- Set radius of sphere
- Specify the radius of the sphere.
Option within the command
After you begin creating a sphere, the following option may be available:
- Diameter
- Specify the diameter of the sphere.
