SPLINE command
Creates a spline.
Icon:
Alias: SPL
Creates a 2D or 3D spline that is open or closed. Options allow you to specify start and end points, fit points, and tangencies.
  1. First point of spline (no tangency)
  2. Second point
  3. Next point
  4. End point
  5. Tangent point to end point
  6. Distance between two drag lines
Methods to create a spline
This command has 1 method to begin creating a spline:
  • First point for spline
You can continue adding unlimited points until you press Enter to end the command.
Begin creating a spline by specifying the start point then:
Second point
Specify the first fit point.
Set next point
Specify the next fit point.
Additional options: [Close/Fit tolerance/Undo]
Select starting tangent point
Specify a tangency for the starting point or press Enter to ignore this option.
Enter tangent for ending point
Specify a tangency for the ending point or press Enter to ignore this option.
Additional options within the SPLINE command
After you begin creating a spline, the following options may be available:
Close
Automatically draw a spline segment between the start and end points to create a closed spline.
Fit tolerance
Specify (in drawing units) how closely the spline matches its fit points. If the fit tolerance is 0, the spline passes through its fit points.
Undo
Undo the last fit point and continue drawing from the previous fit point.
