SPLINE command
Creates a spline.
Icon:
Alias: SPL
描述(D)
Creates a 2D or 3D spline that is open or closed. Options allow you to specify start and end points, fit points, and tangencies.
Methods to create a spline
This command has 1 method to begin creating a spline:
- First point for spline
You can continue adding unlimited points until you press Enter to end the command.
- Begin creating a spline by specifying the start point then:
- 第二点
- Specify the first fit point.
- Set next point
- Specify the next fit point.
- Select starting tangent point
- Specify a tangency for the starting point or press Enter to ignore this option.
- Enter tangent for ending point
- Specify a tangency for the ending point or press Enter to ignore this option.
Additional options within the SPLINE command
After you begin creating a spline, the following options may be available:
- 关闭
- Automatically draw a spline segment between the start and end points to create a closed spline.
- 拟合公差
- Specify (in drawing units) how closely the spline matches its fit points. If the fit tolerance is 0, the spline passes through its fit points.
- 撤销(U)
- Undo the last fit point and continue drawing from the previous fit point.
