SPLINE command
Creates a spline.
Icon:
Alias: SPL
Creates a 2D or 3D spline that is open or closed, or converts an object to a spline.
Method
Set the first point, the second point, and the next ones. You can add unlimited points until you press Enter to end the command.
Set first point
Begin creating a spline by specifying the start point.
Set second point
Specify the first fit point.
Set next point
Specify the next fit point.
  1. First point of spline (no tangency)
  2. Second point
  3. Next point
  4. End point
Options within the command
Object
Converts selected entities in splines.
start Tangency
Allows you to specify a tangency for the starting point.
Press Enter to ignore this option.
end Tangency
Allows you to specify a tangency for the ending point.
Press Enter to ignore this option and finish the command.
toLerance
Sets the fit tolerance. Specify (in drawing units) how closely the spline matches its fit points. If the fit tolerance is 0, the spline passes through its fit points.
Undo
Removes the last fit point and continues drawing from the previous fit point.
Close
Automatically draws a spline segment between the start and end points to create a closed spline.
