STRETCH command
Stretches 2D entities.
Icon:
Alias: S
Note: This command does not stretch texts, shapes, and 3D solids.
Method
Select an area in your drawing using either a rectangular window or a polygon, then specify a base point and a displacement point. All points and nodes inside the selected area will be moved over the specified distance.
