STRUCTUREPANELCLOSE command
Closes the Structure panel.
Closes the Structure panel to hide it from the current workspace. If the Structure panel is stacked when you close it, the Structure tab or icon is removed from the stack.
STRUCTUREPANELCLOSE command - BricsCAD Lite & Pro | Centro Assistenza Bricsys
