TABLET command
Configures digitizing tablets.
Alias: TA
描述(D)
Works only with Windows, and requires that Wintab32.dll be installed in folder C:\Windows\System32.
方式
Toggles tablet mode. Configures and calibrates digitizing tablets.
Options within the command
- ON
- Turns on digitizing mode so that the entire surface of the tablet can be used for picking points and choosing entities, like a mouse.
- 关闭(OFF)
- Turns off digitizing mode to make available the menu areas for choosing commands.
- 校正
- Calibrates the corners of the tablet.
- 配置
- Configures the tablet's menu areas.
