TCIRCLE command (Express Tools)
Surrounds text, mtext or attribute definition entities with circles, rectangles or slots.
Icon:
Method
Select the entities and enter an offset factor.
Options within the command
Circles
Draws a circle around the selected text.
Slots
Draws a slot around the selected text.
Rectangs
Draws a rectangle around the selected text.
Constant
Surrounds selected entities with entities that are all the same size, the size of the largest enclosing entity.
Enter constant slot
Allows you to choose between Width, Height and Both.
Note: This option is available only for Slots and Rectangs.
Variable
Adjusts to the size of each selected entity, based on the offset factor.
