TEXT command
Creates a single-line text entity.
Icon:
Alias: TX
Note: When the TextEval system variable is set to 1, this command evaluates LISP expressions.
方式
There are two methods:
- Places single lines of text in the drawing by specifying height of text and rotation angle.
- Evaluates LISP expressions.
Note: If the text style is annotative, the height value defines the paper space height of the text. The model space height depends on the current annotation scale as defined by the CANNOSCALE and CANNOSCALEVALUE system variables.
Options within the command
- 使用定义的样式
- Changes the text style to use for the text.
- Lists all styles defined in the current drawing.
- 在线对齐
- Aligns text between two points.
- 点之间拟合
- Fits text between two points and prompts for the height.
- 水平中心
- Centers text in the middle of the baseline.
- 中间(水平/垂直)
- Centers text on the middle of the text.
- 靠右对齐
- Right-justifies each line of text.
- 对正选项...
- Displays all justification options. Choose between: Top Left, Top Center, Top Right, Middle Left, Middle Center, Middle Right, Bottom Left, Bottom Center, Bottom Right.
Note: Text can be moved or stretched through grips.
