TEXTMASK command (Express Tools)
Creates a mask behind the selected text or mtext entities.
Icon:
Method
Creates a mask entity behind the selected text or mtext entities, by specifying the mask type and the offset value.
Note: Use the TEXTUNMASK command to remove the mask from the text.
Options within the command
- Masktype
- Allows you to set the mask type.
- Offset
- Allows you to define an offset distance.
