TEXTSCR command
Switches to the text screen.
Displays the Prompt History window (short for "text screen"). This window displays the last 256 lines of command and prompt text. To display greater or fewer lines of history, change the value of the SCRLHIST variable. To return to the graphics screen, enter the GRAPHSCR command or press F2.
Note: A context menu displays when you right click on the
command history. See the full description in the Command line panel
article.
