TINEDIT
Allows editing a topographical surface (TIN surface).
Icons:
Allows you to add or remove points, breaklines and boundaries on a TIN (triangulated irregular network) surface.
Pick points and specify their elevation value to add them to an existing TIN surface or choose another option in the Command line.
Options within the command
Add Points
Sets points to add to a TIN surface.
Add Breaklines
Sets linear entities to be added as breaklines to a TIN surface.
Standard
Adds standard breaklines.
Projected
Adds projected (non-destructive) breaklines.
Add bOundaries
Sets a closed polyline as boundaries to add to a TIN surface.
You can choose the boundary type:
Outer
Creates an outer surface boundary.
Show
Shows the surface boundary inside a hidden surface boundary.
Hide
Hides the surface boundary.
Remove Points
Deletes points from a surface.
Remove Breaklines
Deletes breaklines from a surface.
Remove bOundaries
Deletes boundaries from a surface.
CLip
Clips an existing TIN Surface in the drawing with a selected polygon as the clipping boundary for the surface.
You can choose to remove the polygonal breaklines or not.
Point Location
Allows you to modify a point location by specifying the point to edit location and the new location.
Point Elevation
Allows you to modify a point elevation by specifying a point and entering a new elevation value.
Multiple
Allows you to select multiple points to change their location or elevation.
Delta elevation
Allows you to modify the elevation for multiple points.
Add Line
Allows you to add a new line by specifying the first point and the second point.
Delete Line
Deletes lines covered by a selection window.
Note: The lines to be deleted are displayed in red.
