TINMERGE command
Combines two or more TIN surfaces (or gradings) into a new TIN surface.
Icon:
Combines a base surface and two or more other TIN surfaces to merge with, that will replace the part of the base surface that it covers.
Select a base TIN surface and one or more TIN surfaces to merge with and specify if you want to keep or delete the original surfaces.
