TINMERGE command
Combines two or more TIN surfaces (or gradings) into a new TIN surface.
Icon:
Combines a base surface and two or more other TIN surfaces to merge with, which will replace the part of the base surface that it covers.
Methods
Select a base TIN surface and one or more TIN surfaces to merge with, and specify if you want to keep or delete the original surfaces.
Options within the TINMERGE command
Removal of original surfaces
  • Yes
    The original surfaces are deleted. This options results in a merged TIN surface that cannot be edited.
  • NO
    The original surface to merge is not deleted. This option results in 2 TIN surfaces:
    • Original TIN surface to merge
      When selecting and moving this surface, the merged TIN surface changes accordingly.
    • Merged TIN surface.
