TINMODIFY command
Deforms or smoothens a selected TIN surface.
Icon:
Modifies a selected TIN surface by deforming or smoothening it or creates a new modified TIN surface.
Options within the command
Deform
Modifies the selected TIN surface or creates the deformable part as a new TIN surface.
specify Contour
Creates a deformation with a contour.
select Entity
Creates a deformation with an elevated chosen closed entity.
Note: Net volume = fill-cut.
draw Polygon
Creates a deformation with an elevated polygon.
Smoothen
Modifies the selected TIN surface by smoothening it between the indicated boundaries.
Creates a circular smoothening boundary by indicating a radius value and a location where you want the smoothening.
select Entity
Smoothens the surface part between the boundaries of an entity.
Select a closed entity for the smoothening and choose a location where you want the smoothening.
draw Polygon
Smoothens the surface part between the boundaries of a polygon.
Pick points for a polygon and press ENTER to Close the polygon and choose a location where you want the smoothening.
