TINPROJECT command
Projects a point-based entities or linear entities to a TIN surface.
Icon:
Projects point entities (Point, Block, Text) or linear entities (Line, Polyline, Circle) to a TIN Surface.
Select the TIN surface (1), select the entities to project (2) and choose to keep or delete the projected entities.
