TORUS command
Creates a 3D Solid in the shape of a torus.
Icon:
Alias: TOR
Note: In BricsCAD Lite, which doesn’t support 3D Solids, the TORUS command launches the AI_TORUS command.
描述(D)
Creates a 3D Solid in the shape of a torus. Choose from a combination of options including center and the radius or diameter of both the whole torus and the body of the torus.
Methods to create a torus
This command has 1 method to begin creating a torus:
- 圆环体中心点
- 圆环体中心点
- Begin creating a torus by specifying its center then:
- Set radius of whole torus
- Specify the overall radius of the torus. The radius is measured from the center of the whole torus to the center of the body (tube) of the torus.
- 指定圆环体管的半径
- Specify the radius of the body (tube) of the torus.
Options within the TORUS command
After you begin creating a torus, the following options may be available:
- Diameter (of whole torus)
- Specify the diameter of the entire torus. The diameter is twice the distance from the center of the whole torus to the center of the body (tube) of the torus.
- Diameter (of body of torus)
- Specify the diameter of the body of the torus.
