TSPACEINVADERS command (Express Tools)
Creates a selection set of the text entities that have another entity that overlaps it.
Method
Select the entities you want to check for overlapping entities or type all to check the entire drawing. The number of overlapping entities is displayed in the command line.
Options within the command
- Should each text be queried individually?
 - Allows you to decide if each text should be queried individually.
