UNION command
Performs Boolean union operations on 3D solids and 2D regions.
Icon:
Alias: UNI
Note: In the BricsCAD® Lite license level, the
command applies to region entities only.
Performs Boolean union operations on 3D solids and 2D regions by adding set of entities to another set to form a single entity.
Note: The resulting entity takes on the properties of the ACIS
entity selected first.
Method
Specify the ACIS entities to join into a single entity. The program joins regions and 3D solids into a single entity.
The entities selected:
Result:
