UPDATELAYOUTBLOCK command
Updates an inserted layout block reference.
Method
Updates a layout block reference inserted using the INSERTLAYOUT command according to the source drawing layout changes.
Select inserted block
Select the inserted layout block reference that should be updated.
Note: For the block to be updated, the name of the source file must be the one from when the layout was inserted.
