VIEWUPDATE command
Updates drawing views.
Icon:
Note: The DRAWINGVIEWFLAGS system variable allows to enable
parallel creation or updating of drawing views. This can reduce view processing
time, but uses more resources.
Manually updates the selected or all drawing views created by the VIEWBASE and VIEWSECTION commands when automatic updates (VIEWUPDATE) are turned off.
Options within the command
- Select drawing views
- Updates the selected views.
- All views
- Updates all views in the current layout.
