VISIBILITYSTATES command
Opens the Manage visibility dialog box.
Icon:
描述(D)
Opens the Manage visibility dialog box to create and edit visibility states in the current block definition.
Note: BricsCAD visibility states are not compatible with AutoCAD® visibility states. When you open a drawing with BricsCAD parametric blocks in AutoCAD® they display as saved in BricsCAD. However, when such parametric blocks are edited, or copied to another drawing in AutoCAD®, all entities in the block become visible.
