VISIBILITYSTATESADD command
Adds entities to the active state of the selected visibility parameter.
Methods
The VISIBILITYSTATESADD command adds entities to a selected visibility parameter. The entities added will be visible for the active state of the selected parameter.
Options within the command
- Specify parameter name
- Asks for the name of an existing visibility parameter.
- Select entities to add to <P>=<S> [selection options (?)]:
Asks for a selection of entities to be added to the parameter <P>. These entities will be visible for the state <S>.
<P> is a placeholder for the name of the visibility parameter entered in the previous step. <S> is a placeholder for the name of the active visibility state of the parameter <P>. On the screen, instead of the texts <P> and <S>, the actual names of the parameter and the state will be displayed.
For more information on viewing and managing the visibility parameters and states see the article Visibility states panel.
