VISIBILITYSTATESREMOVE command
Removes entities from the selected visibility parameter.
Methods
The VISIBILITYSTATESREMOVE command removes entities from the selected visibility parameter.
Options within the command
Specify parameter name
Asks for the name of an existing visibility parameter.
Select entities to remove from <P>=<S> [selection options (?)]:
Asks for a selection of entities to be removed from the parameter <P>.
<P> is a placeholder for the name of the visibility parameter entered in the previous step. <S> is a placeholder for the name of the active visibility state of the parameter <P>. On the screen, instead of the texts <P> and <S>, the actual names of the parameter and the state will be displayed.
For more information on viewing and managing the visibility parameters and states see the article Visibility states panel.
