XEDGES command
Extracts edges from 3D entities.
![BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM](https://static.bricsys.com/help/images/V23/en_US/command-reference-pro-mechanical-bim.png)
Icon:
Makes entities out of one or more edges found on 3D solids, 3D surfaces, and 2D regions; extracted edges become 2D entities in 3D space, such as arcs and lines.
Newly created entities are placed in the same location as the source edges, and on the current layer.
