XLINE command
Creates xlines.
Icon:
Alias: INFLINE, XL
描述(D)
Creates an xline (infinitely long line) from a combination of options point, direction, and angle.
Methods to begin an xline
This command has 6 methods to begin creating an xline:
- Set point along line
- 水平(H)
- 垂直(V)
- 角度
- Bisect
- 平行
You can continue adding unlimited xlines until you press Enter to end the command.
- Begin creating an xline by specifying a point on the xline then:
- 方向
- Specify the direction of the xline from the starting point.
- 水平(H)
- Begin creating an xline parallel to the x-axis then:
- 位置
- Specify a point on the xline.
- 垂直(V)
- Begin creating an xline parallel to the y-axis then:
- 位置
- 角度
- Begin creating an xline based on an angle then:
- Enter angle
- Specify the angle of the xline.
- 位置
- Bisect
- Begin creating an xline which bisects two imaginary lines then:
- Set vertex point
- Specify a point at the vertex of the two imaginary lines.
- 指定二等分角起点
- Specify a point to define the first imaginary line. The vertex is used as the other point.
- 指定二等分角终点
- Specify a point to define the second imaginary line. The vertex is used as the other point.
- 平行
- Begin creating an xline parallel to a line or polyline segment then:
- Set offset distance for parallel infinite line
- Specify the offset distance for the xline.
- 选取一个线对象
- Select a line or polyline segment from which to offset the xline.
- 指定要偏移的那一侧
- Specify the side on which to place the xline.
Options within the XLINE command
After you begin creating an xline, the following option may be available:
- 参照
- Select an entity to use as a reference angle then:
- Enter angle
- Specify the angle to place the xline relative to the selected entity.
- 实体
- Select a line, arc or polyline segment to bisect. When you select a line or polyline segment, the command draws the xline perpendicular to the segment’s midpoint. When you select an arc or polyarc, the command draws the xline perpendicular to the arc’s center and point.
- 通过点
- Specify a point through which to draw the xline
- 选取一个线对象
- Select an entity to which the xline should be parallel.
- 指定通过点
- Specify a point through which to draw the xline.
