XPLODE command
Explodes entities.
![BricsCAD Shape; BricsCAD Lite; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM](https://static.bricsys.com/help/images/V23/en_US/command-reference-all.png)
Icon:
Explodes entities providing control over the resulting entities.
Note: This command does not explode attached references,
entities on frozen layers or basic entities such as lines, circles and
arcs.
Options within the command
- Entities to explode
- Selects the entities to explode.
- Separately
- Explodes one entity at a time.
- All
- Explodes all selected entities at once.
- All listed
- Allows to specify all properties for the selected entities.
- Multiple
- Specifies more than one property for the exploded entities by choosing properties one by one.
- LAyer
- Specifies the layer for the exploded entities
- Color
- Specifies the color for the exploded entities.
- LType
- Specifies the linetype for the exploded entities.
- ltScale
- Specifies the linetype scale for the exploded entities.
- Inherit all from parent
- Inherits the color, layer and linetype scale from source entities.
