Add quad button filter dialog box
The Add quad button filter dialog box allows you to select a filter for the quad button.
  1. Selection drop-down list with filters.
Selection drop down list with filters
The list contains three general filters that apply to any object type.
NO_SELECTION The tool is displayed when nothing is selected.
OBJECT_ANY The tool is displayed when one entity (regardless its type) is selected.
OBJECTS_ANY The tool is displayed when many entities (regardless their type) are selected.
Note: It is possible to type in a custom filter, however it is recommended to use the Add Entity Alias dialog box to create a custom filter.
Note: The custom filter format consists of one of the three general filters with object type suffix like _LINE, _CIRCLE, etc. For example: OBJECT_CIRCLE, OBJECTS_SURFACE_EDGE, etc.
