Add scale dialog box
The Add Scale dialog box allows you to add a new scale factor to the list.
![](https://static.bricsys.com/help/images/V23/en_US/DB_addscale_01_V21.png)
- Scale name
- Scale properties
Scale name
Specifies the scale name as it will appear in the scale list.
Scale properties
Specifies the scale factor in paper (size when plotted) and drawing units.
