BIM Typed Plans dialog box
The BIM Typed Plans dialog box lists all Typed Plans in the support folder.
  1. Search
  2. Context menu
  3. Edit typed plan
  4. Add typed plan
Search
Searches all the Typed Plans that matches the words you enter in the search box.
Context menu
Clone
Creates a copy of the selected Typed Plan.
Remove
Removes the selected Typed Plan.
Rename
Edits the name while the text is being highlighted. Press Enter to save and apply the changes.
Edit typed plan
Opens the BIM Typed Plan Editor dialog box which allows you to edit the selected Typed Plan.
Add typed plan
Creates a new Typed Plan.
You can create a template by clicking on the button. By default, the Typed Plan is named New Typed Plan with the text highlighted. After you have added a relevant name for the Typed Plan, press Enter to save and apply the changes. The inserted Typed Plans will be sorted alphabetically. Use the scroll button to navigate through the list.
