Change dictionaries dialog box
The Change dictionaries dialog box allows you to change dictionaries.
  1. Main dictionary
  2. Custom dictionary
  3. Custom dictionary words
  4. Apply & Close
  5. Cancel
Help
Opens the Bricsys Help article for the SPELL command.
Main dictionary
Specifies the main dictionary to use for spell checking.
File name
Specify the dictionary file to use as the main dictionary. Available files are displayed in the drop-down list.
Download
Download additional dictionaries from OpenOffice.org. Opens the Web browser at: https://extensions.openoffice.org/dictionaries
Custom dictionary
Specifies a custom dictionary to use for spell checking. Use custom dictionaries for discipline-specific words, such as medical or mechanical terms.
File location
Specifies the file name and location of a custom dictionary to use in addition to the main dictionary.
Browse
Open the Select Custom Dictionary dialog box to select a custom dictionary file.
Specifies words to be included in the custom dictionary.
Word field
Allows you to enter a word to be included in the custom dictionary.
Add
Add the word you entered in the word field to the custom dictionary.
Words list
Displays all the words included in the custom dictionary.
Delete
Delete a selected word from the custom dictionary.
Apply & Close
Apply your changes and close the dialog box. The custom dictionary file is only updated with added or deleted words after you choose Apply and Close.
Cancel
Close the dialog box without applying changes.
