Create or edit block definition dialog box
The Create or Edit Block Definition dialog box allows you to select an existing block definition
to edit, or to enter a new name to create a new block definition.
Block to create or edit
Specifies the name of the block you want to create or edit. To edit a block, you can select a block from the list below with the blocks available in the drawing.
Preview
Provides a preview of the selected block.
Displays the description of the selected block.
Click OK, to open the Block Editor.
