The Create or Edit Block Definition dialog box allows you to select an existing block definition to edit, or to enter a new name to create a new block definition.
Block to create or edit
Preview
Specifies the name of the block you want to create or edit. To edit a block, you can select a block from the list below with the blocks available in the drawing.
