Create or Restore Version Control Project dialog box
Allows you to create a new version control for a project, or restore an old, deleted version control project. It is opened under Version control panel.
- Project name
- Directory path
- Directory name
- Create directory button
- Advanced Options
- Create / Restore
- Project name
- Specifies the project name.
- Directory path
- Displays the folder where the project will be created. The default path is stored in the VERSIONCONTROLDOWNLOADPATH system variable, but it could be changed by choosing another folder from Please choose a folder to create this project in dialog box.
- Directory name
- Sets the folder name the same as Project name.
- Toggles the display of Directory name (3) field and automatically creates a folder with the project name where the project will be created.
- Advanced Options
- Sets and displays the expressions which define the files that should be ignored in the version control project.
- Create / Restore
- By pressing the button, the version control project will be created. If the folder contains an old, deleted Version Control project, this project will be restored.
