Customization groups dialog box
The Customizations Groups Dialog Box allows you to load or to unload a partial CUI file.
When you install BricsCAD the default CUI files are copied to the Support folder of your Roamable root folder. (e.g. C:\Users\<user_name>\AppData\Roaming\Bricsys\Bricscad\Vxx.x\en_US\Support).
When you launch BricsCAD the first time the default.cui file is loaded automatically.
  1. Loaded Customization Groups
  2. Load Customization Group from File
A list with the names of the customization files already loaded is displayed.
A CUI file can be unloaded by selecting it from the list and clicking the Unload button.
Click the browse button to select a partial CUI file and click the Load button to load it.
