Custom properties dialog box
The Custom Properties dialog box allows you add custom properties for sheet set and sheets.
- Sheet Set Tab
- Sheets Tab
- Add
- Edit
- Delete
Sheet Set Tab
Manages the custom sheet set properties.
Sheets Tab
Manages the custom sheets properties.
Add
Adds a custom property. Displays the Add Custom Property dialog box in which you add a property name and its initial value.
Edit
Allows to edit the value of a selected custom property. Displays the Custom Sheet Property or Custom Sheet Set Property dialog box in which you edit the name of the property.
Delete
Deletes a selected custom property.
